Resultados 1 al 10 de 16
Tema: TomTom One XL Europe 31 - Map installed but not active
    Miembro Avatar de freeaf
    31 ene, 17
    7
    TomTom One XL
    55019
    8014
    725.1915
    Predeterminado TomTom One XL Europe 31 - Map installed but not active
    Hello there,
    Since I am portuguese and I don't know how to speak spanish I will write in English.
    I've deleted my default european map from my TomTom memory to update to a new one. But my new one has more size and I can't use it since my SD has only 2GB.
    I moved my default map again to my SD card and now my TomTom turns on but nothing happens, just stay on boot screen.
    I've open BBS Tools and now this program says I don't have any maps installed (but I have the default map).
    Running TomTom Home 2 will fix this since it downloads the map again?
    Thank you
    EDIT: Since my internal memory card has only 2GB is it possible to find a map only for Spain and Portugal (Iberia) with less then 2GB? My TomTom has european map and I don't really need it since I only drive in Portugal.
    Última edición por freeaf; 31/01/2017 a las 23:31
    2,528
    Cita Iniciado por freeaf [Solo usuarios Registrados pueden ver los links. haz click para registrarte]
    Hello there,
    Thank you
    The map you need is the iberia 980.7898.
    If your navcore is not patched, use the bbstools light forum tool, both to patch and activate the new map.
    I do not know if you have patched the navcore, I guess not, it is necessary to activate the maps
    Bbstools light tool
    Manual to patch navcores
    Manual map activation
    Iberia 980.7898.... Your map is 98
    The manuals are in Spanish, I'm sorry
    best regards
    31 ene, 17
    7
    TomTom One XL
    55019
    8014
    725.1915
    Hello @Pegaso,
    Yes, I did patched something called "TTS or PND" on BSS Tools.
    A summary: After the patch I've done I should download and select the map I want to use on BBS Tools (image under this) and then it's ready to use after this?
    Also, should I move the map first to my TomTom and then select the map to activate it on BBS Tools or I can select the maps folder from my hard drive?
    I ask this because my TomTom internal storage has only 2GB and I can't have both on my storage (I guess, I don't know the new one size).
    Btw, Uploaded has a limit so I can't downloading anything right now...
    Thanks in advance
    Última edición por freeaf; 31/01/2017 a las 22:32
    2,528
    I will send you by private message the map of iberia 9809.7898.
    Once you receive it you unzip it, and the resulting folder you put it in the internal memory of your gps
    Then follow the map activation manual for bbstools light.
    I remember that once patched the navcore, you must restart the gps so that you create a file called ttgo.bif necessary for the activation of the map
    2,528
    I did not notice the navcore you have and I sent you a map that you can not install because of the characteristics of your navcore
    Wait, I'll send you another map that will serve you.
    The iberia 980.7971
    31 ene, 17
    7
    TomTom One XL
    55019
    8014
    725.1915
    Hello,
    Already did that patch and now I have a "ttgo.tif" file and also a "PNDNavigatorBBS".
    After I do this I need to restart my GPS? Also, can I delete my old map folder on my GPS storage?
    Thank you! Gracias
    * I can ready spanish easily but don't know how to write spanish
    2,528
    Hello,
    Thank you! Gracias
    Right, you already have patched the navcore
    Yes, you can also remove the old map folder to insert the new one
    31 ene, 17
    7
    TomTom One XL
    55019
    8014
    725.1915
    Done. I've done everything you said. It's working but somehow after a few seconds of use my GPS shutdown (goes directly to the antitheft image and shutdown).
    Is it an issue?
    2,528
    Is it an issue?
    Do you have a battery?
    I tell you because nothing else to turn on the gps and goes off may be because the battery is low.
    Turn it on and connect it to the pc so it has a continuous battery
    31 ene, 17
    7
    TomTom One XL
    55019
    8014
    725.1915
    It happened while conected onto my PC.
  1. Tomtom XL Europe 31
    Por manuel9984 en el foro Tomtom XL & XXL (todos los modelos)
    Último mensaje: 30/01/2018, 15:05
  2. Ayuda: TOMTOM GO 750 Europe 45
    Por guirusoft en el foro Tomtom GO 540 / 740 / 750 / 940 / 950 Live
    Último mensaje: 20/10/2017, 00:10
  3. Por fin active mapa
    Por inocencio2 en el foro Tomtom GO 520 / 530 / 630 / 720 / 730 / 920 / 930
    Último mensaje: 09/07/2016, 01:06
  4. TomTom One XL Europe
    Por jona97 en el foro Actualizando / Instalando / Configurando
    Último mensaje: 24/06/2016, 22:38
