Resultados 1 al 10 de 16
Tema: TomTom One XL Europe 31 - Map installed but not active
Vista híbrida
    Miembro Avatar de freeaf
    31 ene, 17
    7
    TomTom One XL
    55019
    8014
    725.1915
    Do you have a battery?
    I tell you because nothing else to turn on the gps and goes off may be because the battery is low.
    Turn it on and connect it to the pc so it has a continuous battery
    It happened while conected onto my PC.
    pegasus
    Visitante Avatar de pegasus
    Cita Iniciado por freeaf [Solo usuarios Registrados pueden ver los links. haz click para registrarte]
    Turn off the gps, disconnect it from the pc and shut it again to see what happens
    pegasus
    I'm going to make a proposal, although the same thing you do not need
    If you want we could leave the GPS more modern, with a map and navcore with better features, but only if you want and following step by step my instructions.
    You know, we like to mess around always want to go beyond
    We could do something more elegant
    You must have the option on your PC to see hidden files and folders
    If you want to send you a navcore by private.
    You are going to delete all the content you have right now, and you are going to unpack what you are sending, copy all the folders and files in the internal memory.
    Once copied everything, turn off the GPS, disconnect the pc, turn on gps and advance until you get the screen that says "no maps."
    Then you reconnect the gps to the pc, and in this case you are going to put the first map that I send you, the 980.7898 and activate it with bbstools light
    It should work if or if, and you will have a map with characteristics superior to 980.7971
    If you decide someday you just have to tell me and I send the private with the navcore already cooked, but if you are comfortable with what you have, I also want you to lie and that you can go wrong
    a greeting
    31 ene, 17
    7
    TomTom One XL
    55019
    8014
    725.1915
    a greeting
    To be honest, it's the first time I do this to a GPS. This actually is not mine. A friend asked me, since I work with computers, If I could update his maps and I said: "Well, with a litle research nothing is impossible". After 2/3 hours I finnaly made it and it's working fine.
    And because it's not mine Im leaving as it is. But Im thinking to buy a TomTom and then I will explore a litle bit more the features I can get on this board/forum.
    Tho, this was a really great help because I couldn't find good tutorials since this is an old device.
    Thank you one more time!
  1. Tomtom XL Europe 31
    Por manuel9984 en el foro Tomtom XL & XXL (todos los modelos)
    Último mensaje: 30/01/2018, 15:05
  2. Ayuda: TOMTOM GO 750 Europe 45
    Por guirusoft en el foro Tomtom GO 540 / 740 / 750 / 940 / 950 Live
    Último mensaje: 20/10/2017, 00:10
  3. Por fin active mapa
    Por inocencio2 en el foro Tomtom GO 520 / 530 / 630 / 720 / 730 / 920 / 930
    Último mensaje: 09/07/2016, 01:06
  4. TomTom One XL Europe
    Por jona97 en el foro Actualizando / Instalando / Configurando
    Último mensaje: 24/06/2016, 22:38
